Spy Shots: Audi RS8 has burned down completely
In Germany, at carrying out of the next test arrival on a line the Nurnburgring, has lighted up and the prototype sports penalty Audi RS8 which is estimated approximately in 1 000 000 dollars has been completely destroyed.
Happened while anybody cannot name the exact reason, but most likely it is connected with malfunctions of the new V10-unit capacity approximately in 500-550 horsepowers. Also from some sources it became known, that the test-pilot and its assistant have not suffered, as in time have left the car having got off an easy fright.
As is known, Audi during the given period of time усиленно works above the given RS8-model to be in time with the Frankfurt motor show where it will be officially presented. In turn the conclusion a superpenalty on the European markets is planned in 2009.
som de sto over var dette en prototype
Gammel nyhet. Det der er en R8 V10. Kjørte noen runder på ringen før den brant opp.
