Feilmeldig! motorlampa lyser etc...noen som kan "tyde"
Bil: Audi A6 Avant 2,7 Biturbo 2001. Km 140000. Alle servicer fulgt.
Fikk lest av følgende feilmeldinger :
1.) 18010.P1602 Power supply (B+) terminal 30:low voltage
2.) 17831.P1423 Secondary air injection system, Bank 1:air flow to low
3.) 17819.P1411 Bank 2 secondary air system: air flow to low
Hadde vært greit å fått denne kjærra opp å gå som den skal snart...
1)18010/P1602/005634 - Power Supply B+ Terminal 30: Voltage too Low
Possible Causes
Cables on the Battery were removed
Battery weak (voltage)
Generator Disfunction
Possible Solutions
Check Battery Cables
Check/Replace Battery
Check/Replace Generator
Special Notes
If multiple Control Module have Power Supply Faults stored, it's most likely to be one common Problem like the ones shown above. Otherwise when only one or two Control Modules have such Codes stored you better start searching at the individual Power Supply of these Modules.
17831/P1423/005155 - Secondary Air Injection System; Bank 1: Insufficient Flow
Possible Symptoms
Malfunction Indicator Light (MIL) active
Possible Causes
Fuse for Secondary Air Injection Pump blown
Vacuum Hose(s) leaky
Piping between Secondary Air Injection Pump and Secondary Air Injection Valve leaking
Possible Solutions
Check Fuse for Secondary Air Injection Pump
Check Vacuum Hose(s)
Check Piping between Secondary Air Injection Pump and Secondary Air Injection Valve
17819/P1411/005137 - Secondary Air Injection System; Bank 2: Insufficient Flow
Possible Symptoms
Possible Causes
Possible Solutions
Mange takk!!!
Hvor finner du dette ?
Noen som vet hva som er typiske feil ved disse feilmeldingene ?
