Pioneer TS-W121SPL /UD-G305 + haltec e6x+ stoler
Heisan.
Ønsker selge mine 2 stk Pioneer TS-W121SPL med gitter, hvet ikke hva di er verde i dag.. men kosta bra når dei var nye.. er altforlite brukt og Da har eg fått seter i bilen og trenger "bass-plassen" til andre ting, så er fortsatt til salg.
168257_10150366447380527_873050526_16899
montert i en kasse fra BS-bildeler:
BaseBoxx Basskasse 2x12 - Wedge
(76x38x20/47cm)
Pioneer TS-W121SPL subwoofers includes:
* Short description - SPL C-Type Subwoofer
* Interlaced Glass Fibre/Carbon Fibre Reinforced IMPP cone
* Wide-roll, 3-layer fibre woven radial surround
* Double-stacked high power magnets
* Silver binding post terminal
* Aluminium die-cast basket with bottom hold structure
* Extended and vented pole yoke
* Dual 4 ohm voice coils (2 or 8 ohm)
* Enclosure use
* Frequency response - 18 - 2.000 Hz
* Sensitivity (1W/1m) - 89 dB
* Recommended sealed enclosure (Litres) - 42.5
* Lowest resonance frequency (FS) - 32 Hz
* Maximum Power - 2.000 Watt
* Nominal input power - 750 Watt
* Vas - 34.53 l
* Woofer size (cm) - 30 cm
* Dual 4-ohm voice coils: 2 or 8 ohm
håper på 2000,- + for dette.
frakt i tillegg
Oppner denne tråden da eg synes dette vart vel trangt i bilen med seter i,Eg bytter gjerne bassene bort i en
Pioneer TS-WX77A
:-D
Har også 2 stk pioneer TS-W203F 8"
8" Free-Air Component Subwoofer
* Diamondplate Foamed IMPP (Injection Molded Polypropylene) Rigilite™ Composite Cone Woofer (Titanium Grey)
* One-Piece Cone Construction for Reduced Distortion
* Dual-Layer Urethane Surround
* Direct-to-Cone Voice Coil Mounting Ring
* Conex Damper with Damper Ring
* Lead Wires Integrated into Damper for High Reliability and Improved Power Transfer
* Oversized Glass-Imide Voice Coil Bobbin
* Projected Pole Yoke with Vented Pole
* High-Energy Strontium Magnet with Bumped Back Plate
* Free-Air Design
* 350 Watts Max Music Power
* 120 Watts Nominal Power Handling
* Frequency Response: 25-3,000Hz
* Sensitivity (Efficiency): 91dB (1W/1m)
* 4 Ohm Rated
kostet en 800,- pr stk da eg kjøpte dei, har ligget å slenge lenge..
bud over 600,- + frakt ??
Selges som PAR.
ein liten Søndagsskubb.. er her fortsatt.
Selge ogso en Haltec E6x med kabelmatte, skal ha vert på ein sierra av noko slag.. har ikkje prøvd den selv.
bud 3000,- + frakt..
Lagt til etter 5 dager 22 timer:
Har også noen orginale Chess stoler(vanlige ca 95´km i bruk) understellet er slitt da eg byttet da eg satte inn skinn i bilen.
pris 500,- +++ ?? bør vel hentes..
har fortsatt 1 stk TS-W121SPL med gitter,2 stk pioneer TS-W203F 8" og Dynabell kondensator.
pakkepris 1500,- + frakt .
ein liten vår-bumpidump..
Får ikkje endret første innlegget,Haltec´n er solg..
har 1 12" , 2 8" org stolene..
