Mediatråd for O.CT Tuning
VW Golf V GTI E 30 - steg 3+
365hk og 500nm
En liten lydtest:
Flere bilder av vår Golf V GTI E30 Steg 3+
Info om steg 3+
- software fra O.CT Tuning
- endret luftinntaket
- O.CT Tuning racing eksos uten katalysator og mellompotte i 76mm
- RS2 tennplugger
- høytrykkspumpe
- O.CT Tuning Coilover v3
- O.CT Tuning Carbon bekledning motorrom
En liten film fra dynoen av en annen E30
Audi A1 Quattro powered by O.CT Tuning
Steg 1 med 305 hk, steg 2 er også utviklet for den som ønsker enda litt mere....
Enda mere Audi A1 Quattro powered by O.CT Tuning
Lydtest:
Audi A7 3.0TFSI powered by O.CT Tuning med 22" O.CT Tuning lettvektsfelger.
Audi ®S3 RWD 2,7T made by O.CT Tuning
2003 Audi S3
Engine: 2.7 liter bi-turbo RS4 V6 swap with O.CT Tuning software and injectors, larger K04 turbos, custom FMIC and piping, fabricated 70mm dual turbo-back exhaust system, custom intake, aluminum radiator with dual electric fans, rear-mounted battery and fuel cell
Driveline: RWD conversion using Quaife six-speed transmission, custom bellhousing, transmission mounts and driveshaft, Dana 44 rear end inside custom aluminum case, Corvette ZR1 rear axles, Spec stage 3 clutch
Suspension: fabricated McPherson front and rear strut suspension design, tubular control arms, KW coilovers, O.CT front and rear sway bars and strut tower braces
Wheels & tires: 18x8.5" (front) and 18x11.5" (rear) Work Meister S1 three-piece wheels, 235/40-18 (front) and 295/30-18 (rear) ContiSportContact 2 tires
Brakes: 380mm (front) and 322mm (rear) cross-drilled rotors, dual Porsche calipers (front) and single four-piston (rear) on fabricated carriers
Exterior: 60mm (front) and 100mm (rear) widened steel fenders, widened RS4-style front bumper, stock rear bumper and side skirts
Interior: carbon dash, console, steering column, door cards and interior pieces, Sparco 380mm three-spoke steering wheel, Stack Racing instrument cluster with LED gear indicator, Porsche GT3 seats, rollcage, Quaife polyurethane shift knob
Audio/Visual: 550 thundering horses as a soundtrack
En liten film fra banekjøring med denne spesielle Audi ®S3 RWD
Audi A8 (4H) powered by O.CT Tuning - 22" O.Ct Tuning lettvektsfelger
Audi & BMW powered by O.CT Tuning
Audi Q7 powered by O.CT Tuning
Audi RS6 powered by O.CT Tuning, Carbon folie på taket ++++
Effekt OEM: 380 HK
Effekt O.CT Tuning: 452 hk
Moment OEM: 580 NM
Moment O.CT Tuning: 625 NM
PDF info dokument
Parallel full hybrid drive:
The supercharged 3.0 TFSI V6 engine with 333 hp (405 hp O.CT) is supported by an electric machine with 47 hp on demand. This delivers a combined output of 380 hp (452 hp O.CT).
Using the electric machine for boosting the performance results in 580 Nm (625 Nm O.CT) at 1000 1/min!
The power enhancement is achieved through reprogramming of the ECU (Electronic control unit). Bring your car unmatched dynamic performance where you can experience pure driving pleasure.
We offer serious tuning and we keep our promises.
Å bygge fine eksosanlegg er en egen kunst,
ta en titt på dette håndverket!
Audi A4 1.8T powered by O.CT Tuning
VW Beetle 1.6TDI
Prøvekjøring av Audi RS5
Audi A1 1.2TSI powered by O.CT Tuning, demobil......
VW Passat 2.0 TDI Alltrack powered by O.CT Tuning
BMW X5 3.0 TDI powered by O.CT Tuning
Audi A4 1.8T Quattro powered by O.CT Tuning
Audi urquattro powered by O.CT Tuning
Audi RS5 på testkjøring
Alm Racing powered by O.CT Tuning
Vags nye 3.0 TDI Biturbo 313hk originalt, før og etter O.CT Tuning
Audi R8 4.2 V8 kompressor kit by O.CT Tuning
Roger sin bil i benken, forøvrig en av O.CT Tuning sine dyktige medarbeidere i Norge!
Audi A6 powered by O.CT Tuning
Sist veke var me 2 som reiste på besøk til moderfirmaet:
Hovedkontoret i Østerrike
902282_10151595502249396_1738251091_o.jp
Demobilen til Rieger Tuning, Audi A3 2.0 TDI CR 150 hk, verdens første av sitt slag som er optimalisert via bilens diagnosekontakt! :)
906922_10151595500314396_1747826489_o.jp
604176_10151595500289396_1373528019_n.jp
892873_10151595500339396_1258421422_o.jp
- - - Updated - - -
Audi A8 optimalisert av O.CT Tuning
Et lite utvalg av O.CT Tuning sine egne felger
383025_10151595502054396_1771308200_n.jp
292271_10151595503089396_1179156468_n.jp
533320_10151595504009396_2009208989_n.jp
- - - Updated - - -
Bil bygd av O.CT Tuning - byggekost over 200 000€
901394_10151595502339396_1323701038_o.jp
883986_10151595507684396_1767685111_o.jp
Mere amerikanske muskler
Nybygd 7,1 liter kompressor motor, byttet ut 6,2 liter kompressor motor
893230_10151595502919396_1924653685_o.jp
905451_10151595507904396_1158927281_o.jp
Diverse snacks
Audi RS6 steg 3 powered by O.CT Tuning
906506_10151595505054396_2074444942_o.jp
904506_10151595505074396_1379322585_o.jp
905569_10151595505809396_1734731943_o.jp
892107_10151595505764396_1184925895_o.jp
