1 Kanal Mono forsterker Pioneer GM-D510M - 300W RMS @ 4ohm
Rydder hjemme og har BOSE i bilen så alt av bilstereo skal selges unna.
http://www.pioneerelectronics.com/PUSA/Car/Amplifiers/GM+Series/GM-D510M
1700kr som kan diskuteres ved hurtig handel
Peak Music Power 1000 Watts
Number of Channels 1
Load Impedance Capability 2 ~ 8 Ohm (Mono)
Continuous Power (4 ohm) 300W x 1
Continuous Power (2 ohm) 600W x 1
Continuous Power Bridged (4 ohm) N/A
Frequency Response 20 ~ 240Hz
Total Harmonic Distortion 0.03%
Signal-to-Noise Ratio 100dB
Dimensions 10-3/16" x 2-1/16" x 9-13/16"
Features
Channel # Capability 1
Class-D Design
PWM Regulated MOSFET Power Supply
MOSFET Output Section
Screw-Type Speaker Terminals
Balanced Isolator Input Circuit
RCA Inputs Gold 2ch
Input Level Control Hi-Volt (200mV ~ 6.5v)
Built-in Crossover Variable LPF (40~240Hz, -24dB/Oct.)
Bass Level Control -22 ~ +12dB
Opp! :)
Kom med prisforslag via PM.
