Harman/Kardon CA470 - 4 kanals forsterker
Selger en Harman/Kardon CA470 4 kanalsfosterker.
Denne er lite brukt, trolig montert i bilen tidlig i våres av forrige eier, men pga endret behov selges denne.
Tror denne har gått ut av produksjon hos produsenten, er en tøft forsterker som egner seg til mye.
Selges 1000,- + frakt (140,-)
litt spec:
- Class AB
- 4 x 85w RMS @ 4 Ohms (CEA-2006 Compliant)
- 4 x 135w RMS @ 2 Ohms
- 2 x 270w RMS @ 4 Ohms bridged
- Extruded Aluminium heatsink with cast end pieces and clear top plate – blue backlit logo panel
- 8Ga. power terminals with Allen headed grub screw connection
- 4Ch RCA input and 2Ch RCA output
- 12dB per Octave high/low pass crossovers 32Hz to 320Hz
- Subsonic filter variable 12dB per Octave 10Hz to 80Hz
- Proprietary Input Management System sockets in & out on RJ45 Ethernet cable connectors
- Input sensitivity: not quoted but they do explain how to set it in the manual sheet
- Stereo & bridged operation
- Frequency response 10Hz to 100kHz
- Signal to Noise Ratio 104dB
- Channel separation not quoted
- Fuse Rating 20A x 3
- HxWxD(mm) 62 x 404 x 234mm
- Complete with two Allen wrenches long screws and three spare fuses
