1.6 engine wanted..motor ønskes..
hi
Im hoping to buy off someone here a 1.6 engine with hydraulic tappets like from a golf 2 driver model.
I drive a 77 1.6 golf and the engine is getting a little tired so would be nice to put a later one in.
Think hydraulic tappet models started from around 87.
Doesn't need to inc carb as i have a weber replacement one.
live in trondheim but I'm willing to travel.
let me know what you got.
Oh and I'm still needing a bronze windscreen if someone has.
thanks
Sam
1,6 aft 101hk from 97 golf 3. with gearbox and all wiring and instrument, and ecu 2000kr
sorry for late reply, i thought i would be emailed a warning that someone replied.
Do you know if earlier manifolds will fit so i can fit a carb? (wanna keep it looking fairly stock so hoping a mk2 manifold with a weber would fit)
Where are you living?
The 101 hp 1.6 is a cross flow engine, so the earlier manifolds will not fit.
Thanks Per
I realised it after googling the engine
Is 1995 the last year that i can fit my carb manifold to?
For the 1.6, yes. The 1.8 90hp engine was made to 97, and that is the last I know of. Shouldn't be that hard to find a 1.6 though.
Why not use a 1.8 90hk Mk2 engine instead?
I've done 1.8 16v conversions before in the UK but in Norway you have to have it inspected and approved plus all things fitted seem to need TUV certificates.
i got the coil overs approved in trondheim but they complained the offset of my ronal turbos were 1mm above what vw recommend so not legal!
So im guessing its very difficult to get a performance modification approved?
When it come to approval a weber insted of pierburg is equally illegal as 1.8 8v vs 1.6 8v
i was hoping to get the weber approved. if you have any tips of how to get a 16v approved or what i need to show for approval that would be great.
Its difficult to find info on getting approval on modifications.
thanks
There is a forum thread on it in the classic part. 16v demands gti spec brakes.
still looking for a 1.6 87-95 model petrol engine and 5 speed box.
would be great if its from sør or nord trondelag but will consider from anywhere : )
